Obs swap 5.3 vortec
Old Jan 20, 2023 | 04:57 PM
Luii's Avatar
Default Obs swap 5.3 vortec
I swapped my 96 obs with a 2002 5.3 dbw. I did the heads sit valves new injectors wires plugs cam and crank sensor tps cleaned intake and throttle body. The trucks sounds good when I start it it idles good it responds good after about maybe 10 to 15 minutes of driving it starts running rough and misfireing a little it still drives doesn’t turn off or anything but it starts running rough.if I turn off the engine mid restart it will restart fine turn on me idle good and 2 3 minutes later it starts running rough again. Anyone might have a clue of what’s going on ? I have one code nd it is p0118
Old Jan 20, 2023 | 06:01 PM
P0118 is engine coolant temperature circuit.
Check your temp sensor wiring, as it will affect the tune.
Old Jan 20, 2023 | 06:41 PM
Luii's Avatar
I was checking my 02 sensors I had them backwards I had bank 1 on bank 2.changed those around took a drive everything seems fine but I do want to get rid of that check engine light. I rewird the coolant sensor I know yellow is to 74 blue connector but I don’t know where the other wire goes too if it’s just ground or goes to a pin on the pcm Any ideas???
Old Jan 20, 2023 | 10:26 PM
You mighy want to check a schematic for the coolant temp sensor wiring,
Check google for a coolant temp sensor circuit diagram
