04 5.3 into 94 4x4
I have an opportunity to grab a 94 OBS 4x4 (sentimental) and would like to swap my 5.3 into it.
Is the 94 a 4L60E, and what is required to wire it up with my DBW LS? I am thinking purchasing aStandalone harness although I have the complete truck to pull from.
Yes I am a good fabricator but my wiring abilities are fairly primitive. When you say use factory harness and pcm, i would like to do that but not sure what needs to be cut back, etc. Are you saying to swap over under hood fuse block and all of that?
Would a 4x4 4L60E from 2004 be a direct swap behind my 2004 5.3? What i mean is, would the pcm recognize/drive the transmission without any modification?
