2001 Jaguar S type LS Swap
Old Apr 1, 2023 | 06:31 PM
Impaladre's Avatar
Default 2001 Jaguar S type LS Swap
My dad has a 2001 S type Jaguar with a broken down 4.0 that he's been tinkering with for 5yrs and instead of fixing it I want to buy a 5.3 ls/4l60e to put in it.. I'll be painting it myself soon and I've already reupholstered his interior, he'll be 74 this yr and wanted to finally get him on the road... I owe that to him everything he's done for me
How can I make this work as far as a parts list and modification?
For instance, what oil pan?
1.Do I need a modified trans mount?
2. Which motor mounts?
3.Shortened or modified driveshaft?
4.Anything we need to do to get rid of error codes?
5. Should we look for an LS with drive by wire throttle or electonic?
This will be our first attempt for an LS swap
After his is done, I want to put ether a 5.3 or 6.0/4l80e in my 63 Impala
Basically I need a parts list and tips you may have and things to avoid, thanks in advance
Old Apr 6, 2023 | 04:20 PM
sixt9er's Avatar
There's a website called Jags that run or something like that. They have all your swap needs along with tons of information.
Old Apr 8, 2023 | 12:41 AM
Impaladre's Avatar
Thank you I'll definitely check them out Sir
Old Apr 16, 2023 | 04:24 AM
Impaladre's Avatar
I checked out Jagsthatrun they have a swap kit, can anybody give a diagram on a wiring harness or which pins I should move around?
Which is easier to swap drive by wire or drive by cable?
What exhaust or headers would I need?
Old Apr 16, 2023 | 09:39 AM
Project GatTagO's Avatar
Are you referring to the car wiring or for the engine harness? I would go with a Terminator X Max ECU, and DBW.
Andrew
