Engine pull issues
Old May 15, 2023 | 08:54 PM
01Cammie's Avatar
Default Engine pull issues
In the process of dropping the engine out of my 01 v6 Camaro. Got the engine, k member, struts, sway bar, trans crossmember, drive shaft, exhaust out.. lifted the body off with engine hoist, engine came out fine, trans is hung up somewhere.. what am I missing? It looks like is hung up with the torque arm does it need to come out completely or unbolt where it’s attached at the tail of the tranny?
Thanks in advance.
Old May 15, 2023 | 10:52 PM
You need to unbolt the arm from the tranny or it will hang up
