Another, another, another 911 ls swap
Old May 17, 2023 | 09:18 PM
royb's Avatar
Default Another, another, another 911 ls swap
Good evening everybody, I hope everyone is well. I am starting this thread to document my swap and discuss solution and problems along the way. Heres some background information about myself. I am 19, live in fort worth texas and work at a MB dealer as a service technician. Let me start out by saying I am by no means experienced in the world of swaps. I am still getting my feet wet in the automotive industry and am learning every day so please forgive me in advance for my lack of experience and understanding.
Alright, now for the details. I am performing the swap on a 2001 911 C2. It is originally a 3.4 automatic. My uncle bought it brand new back in 2001 and i bought it from him 3 years ago. I bought it with 52k miles and daily drove it UNTIL i believed i heard a knocking. I then let the car sit for 18 months. I recently took it to the porsche dealership for a diagnosis on the engine to find out what exactly what is wrong with the engine so i could list it for sale accordingly. Fortunately/unfortunately the dealership said its operating as designed and they couldn't find anything wrong with it. So maybe I should've had it diagnosed before i bought half the parts for the swap. Oh well you live and you learn, no more jumping to conclusions. So, as we stand, the engine and automatic transmission have been removed and are available for sale if anybody is interested in those (72842 miles). I have removed the automatic shifter housing and shifter cable and replaced it with the manual shifter and manual shifter cables. I also installed the blue hard clutch lines and the manual pedal set. I think thats as far as I've gotten so far.
For reference the new engine is a 6.2 ls3 (from a 2010 camaro) that has been machined. it has a texas speed f35 cam, gm performance ls7 lifter kit,tsp hardened pushrod kit, melling high volume oil pump kit, melling high performance engine bearing kit, meahle gm oe overhaul kit. It is DOD deleted.
I've ordered practically the entire CPE catalog. I've started a youtube channel as well to document the build so feel free to check that out as well if you'd like. https://www.youtube.com/@Roybuilds
That'll be all for now, ill continue to update this with updates and questions. Thank you all and God Bless.
Old May 23, 2023 | 08:00 PM
royb's Avatar
Listed below are the parts I've purchased along with their prices for future reference for anyone interested on swapping their 996. Hoping to be able to work on the car this weekend.Porsche 911
  • Axles $216.49
  • Clutch and brake pedal assembly $143.79
  • Manual transmission cables $97.43
  • Manual transmission $2,134.97
  • SPEC stage 2 clutch kit $725
  • CPE flywheel $1,049
  • CPE powertrain mounting package with brace $2,315
  • Clutch master cylinder $64.89
  • 6 speed gear selector $159.68
  • Clutch slave cylinder $126.48
  • Manual trans bracket $50.37
  • Manual transmission bracket $45.36
  • Brake fluid reservoir $49.99
  • 8x 42lb injectors $129.89
  • Ls3 intake $400.53
  • Ls3 Camaro starter $85.46
  • Ignition coils and brackets $205.66
  • Steel braided clutch line cpe $212.50
  • Cpe induction package $600
  • Cpe cooling package $850
  • Cpe AC package $1350
  • Cpe wire harness with E38 ECM $3300
  • Oil psi adapter fitting $25
  • Coolant psi adapter fitting $25
  • Replaced motor mount bracket $150
  • Canton racing oil pan stud kit 22-302 $21.73
  • Canton racing flywheel cover 21-870 $39.60
  • Ict billet idler pulley 551528 $31.91
  • Ict billet ls bracket $69.99
  • BBK Camaro shorty tuned headers $503.35
  • Canton racing 15-276 oil pan $441.66
  • Canton racing pickup tube 15-277 $94.85
  • Canton racing oil filter mount 22-631 $238.00
  • Engine dipstick 20-850 $23.82
  • Ati harmonic balancer 917303 $394.84
  • Harmonic balancer bolt $8.09
  • Spark plugs
  • Spark plug wires
  • Corvette Water pump 45004WT $163.02
  • Water pump bolts $23
Thats quite a bit of what i've purchased. Im sure i'm going to continue purchasing things as i make progress but that should be good for now.
Old Apr 11, 2024 | 03:26 PM
royb's Avatar
Been quite some time since I've posted on here. I have been documenting the swap on my youtube channel https://www.youtube.com/@Roybuilds
Not too far from "finishing" the swap. Need to build my exhaust and tidy up a few things, all of which will be featured on my youtube channel.
Old Apr 11, 2024 | 05:25 PM
Full Power's Avatar
Originally Posted by royb
Been quite some time ...........
"finishing" the swap. Need to build my exhaust and tidy up................................................ ......
Nice shopping list.
Care to post some pictures of your build ?
How you run the exhaust ?
WHere's the radiator go ?
Missed the part about your electronics: What ECM you decide on ?
Porsche have open differential, or is there clutches in there ?
