Ls3 vs procharger
Old May 20, 2023 | 03:57 PM
Tommy42088's Avatar
Default Ls3 vs procharger
So I've been looking hard into putting a Procharger on my truck. It's a 2000 single cab silverado with a 5.3 with 243 heads which are cnc port, polished and milled .030 with 660 dual springs. Anyways the truck has a 4l65 transmission and I'm not thinking the transmission will handle the power. It hasn't failed me yet with 550 rwhp but I'm looking to put down 750 but here's the thing. The price I will pay for a Procharger and a transmission I can get a full ls3 swap with 10 speed transmission. If it were you guys would you go the Procharger route or do the swap??? My 5.3 runs good and pulls strong for what it is but this has me thinking.
Old May 21, 2023 | 09:09 AM
Ls1Rx-7's Avatar
How can you get an Ls3 with a 10 speed? Thats an LT engine that has the 10 speed in it and it requires the entire LT harness, ecu, bcm to work. Last i checked there wasnt a company out there offering a stand alone controller for the 10 speed. If that was possible id go the 6.2 10 speed vs a procharged 5.3 and 4 speed. The 5.3 would be an absolute dog down low with a procharger, i had one with an F1a and it wasnt fun.
Old May 21, 2023 | 09:40 AM
Tommy42088's Avatar
I might be mistaken the engine then, I mean I can get the full swap out of a new Camara with the 10 speed transmission and if i get the swap everything would be included, harness, ecu, etc. I could take whatever is needed from the car. . And really? The guy who does all my tuning also is a performance mechanic and he suggested the procharger route. I was looking at turbocharging it at first and he told me I shouldn't go that route because I drive the truck on the street and also that my setup wouldn't work well with the turbo. Also what car comes with the motor and transmission your referring too
Old May 21, 2023 | 10:34 AM
2017 was the first year the Camaro SS came with the 10 speed tranny.
Old May 21, 2023 | 10:39 AM
Tommy42088's Avatar
Ok, i can still get that whole swap for around the same price.
Old May 22, 2023 | 06:48 PM
rpturbo's Avatar
A Procharger and a 4l80 will bolt into your car.
The LT/10 spd swap is going to be a TON of work, so unless the labor is free, there's no way the $ is even close to even.
Old May 22, 2023 | 08:58 PM
Tommy42088's Avatar
Im aware, and i can do the labor. Bob at brutespeed told me 7 grand for the procharger kit, the truck has 42lb injectors so I may have to upgrade and it's already on e85 with an aeromotive pump so I'd have to add a second pump and I was expecting around 3-4 grand for a good transmission. Versus a donar camaro that I can everything needed out of, motor, tranny, wiring harness, ecu and whatever else is needed. I'd have to do a little research to see what else I would need from the car. But that's my options and what I'm contemplating.
