Psi Conversion manual to 4L60E
Old Jun 2, 2023 | 03:16 AM
Pompelen's Avatar
Default Psi Conversion manual to 4L60E
Hi, I have a none elctric transmission wiering harness from PSI Conversion. What do i need to convert it to fit a 4L60E.
Old Jun 2, 2023 | 06:41 AM
EDS01SS's Avatar
Just need the year of the transmission, the proper pigtails for that transmission and the wiring schematic for transmission to computer. You could probably just talk to PSI and they could make you one.
Old Jun 2, 2023 | 08:06 PM
LS1 TJ's Avatar
I kind did the same thing on my LS6/T56 C10 swap. Went to a 4L60E. I took the easy way out and sent the harness back to Howell and they reworked it to work with the 4L60E. They also reworked the ECM to work with the 4L60E. Went great. I bet PSI could do the same.
