64 C10 12:1 6 liter
Old Jul 3, 2023 | 08:55 AM
ZONES89RS's Avatar
In-Zane Moderator
Default 64 C10 12:1 6 liter
Moving right along
Old Jul 3, 2023 | 09:56 AM
Ls1Rx-7's Avatar
Man theres nothing better than a high compression Ls it sounds amazing! True duals? X pipe im assuming? What rpm are you shifting that thing? It sounds like 7,000+
Old Jul 3, 2023 | 10:32 AM
ZONES89RS's Avatar
In-Zane Moderator
1 7/8 stainlessworks headers, 3” X pipe, 6” long dynomax bullets dumped at the axle
rev limiter is 7500 and I tickle that between shifts. It feels like it wants more as it isn’t nosing over when I shift lol
and thanks. 6 months of restoring this truck has finally paid off. Extremely happy with the looks and how it runs. Just need to cool it down some more. Runs 205ish and I don’t like that.
Old Jul 4, 2023 | 01:07 PM
Ls1Rx-7's Avatar
205 is absolutely fine for an Ls Especially if ifs an iron block
Old Jul 4, 2023 | 05:12 PM
rkupon1's Avatar
Dude, she s bad! Well done. Sounds amazing
Old Jul 4, 2023 | 07:16 PM
Bigworm81's Avatar
Sick C10 build you could make it run cooler but nothing wrong with 205
Old Jul 5, 2023 | 05:56 AM
ZONES89RS's Avatar
In-Zane Moderator
y’all are both correct. But my concern is that’s where it stays usually. It still climbs higher and I’m not OK with that being 12:1.
if it maxed out at 205 I wouldn’t worry. But that’s just sorta where it hangs out when cruising usually. I don’t want to rattle this thing apart. It’s carbed so no EFI control to pull timing if there is detonation and I wanna be able to beat the **** out of it any time and not worry about getting hotter. Lol
Old Jul 21, 2023 | 07:47 PM
Ls1Rx-7's Avatar
What kind of fan setup do you have? Any ducting to seal it off? Most trucks have yuge radiators so you might want to look into better fans like brushless style that will move a ton of air. Delta pag makes a great fan and stand alone controller thats pricey but works. https://deltapag.com/
Old Jul 24, 2023 | 12:04 PM
ZONES89RS's Avatar
In-Zane Moderator
Went to a 4 row and a single Taurus fan off Amazon. So far it is doing much better.
it will get over 200 sitting still by a bit. But, once I’m moving again it drops down below 200. Good enough
