3.8 to 5.3 lm7 swap thread
Old Sep 5, 2023 | 10:57 AM
skl3t0r's Avatar
Default 3.8 to 5.3 lm7 swap thread
I want to swap a 5.3l lm7 into my 1997 bird with a 3.8l v6. I'm looking for information on the swap- problems in compatibility/install/running, etc. From what I've read, The lm7 should just bolt straight on to ls1 mounts with no issues, and I'm assuming all other accessory components should fit as well? I know heads/intake go right on with no problems. Also, regarding the wiring harness, Is it worth it to grab a terminator X to avoid having to buy a new ECU, or is it a smarter choice to bite the bullet? What else should i know about the engine or the car before i make any final decisions and go through with it? If anyone has info on the swap it would be greatly appreciated!
Also, I don't want to sell it and buy a new one. It's Bright Purple Metallic.
Old Sep 5, 2023 | 11:31 AM
Bylt Performance's Avatar
What transmission are you planning to run? That would define your ECU choice a little bit more.
Old Sep 5, 2023 | 12:15 PM
strutaeng's Avatar
I don't know anything about the F body's, but I would think it would be a plug and play mostly swap, given how GM built vehicles on these generations with the different engine combinations. The LM7 would be very similar to the LS1.
I did a 1999 Silverado RCSB 2wd 4.3 to 5.3/4L80e swap about 3 years ago and everything was plug-and-play. Just got VATS deleted from the 5.3 ECU and reflashed for the transmission and the harness repin. The engine is bone stock and made the truck so much more enjoyable to drive. ☺️
You are going to love it!
Old Sep 5, 2023 | 12:42 PM
skl3t0r's Avatar
BorgWarner t56, lt1 version. Don't have the dosh for a brand new magnum.
Old Sep 5, 2023 | 12:45 PM
skl3t0r's Avatar
Oh my lord. you don't know how much of a relief that is to hear. almost everywhere i've asked so far i get "buy another car" or something else that feels negative. I have the whole build priced out already. Got a spreadsheet going and everything. Just have to actually buy the parts LOL
Anyway, I really appreciate that! thank you for telling me.
Old Sep 5, 2023 | 01:17 PM
bleepster's Avatar
Can I swap one of these engines into my V6 F-body?
While it can be done, installing a larger V8 engine into a car originally equipped with a lower output V6 is generally cost prohibitive and not recommended. Swapping to a LS based engine will typically require a new transmission, engine cradle, radiator, fuel pump assembly, gauge cluster, PCM and wiring harness, strengthened suspension components, and new throttle assembly. With the low cost of entry for these cars, it may be more financially solvent to sell your V6-powered F-Body and buy a V8-powered one to replace it.
Any additional components I may need for a swap?
When swapping in a new engine, be sure to have the correct oil pan and exhaust headers/manifolds needed to fit the F-body chassis. Using an intake and fuel injector setup other than the LS1 components will require a new wiring harness. Additionally, you will need the correct LS1 accessories/accessory brackets to properly fit everything in the engine bay.
taken from: Camaro and Firebird: Guide for Budget Engine Swap | Ls1tech
also a good read:
V6 to V8 swap thread | Firebird Nation
Old Sep 5, 2023 | 01:31 PM
skl3t0r's Avatar
Again,I know it's not that cost effective, But I'm looking to hold on to my 1 of 6 convertible here. I read the whole of the Firebird nation one- that's how I made my spreadsheet. At this point I'm mostly looking for technical advice- stuff to watch out for, prep work to do, a timeline, whatever. Advice on the process.
Old Sep 5, 2023 | 01:38 PM
bleepster's Avatar
from your first post - you make it sound like you want "plug n play" - that will not happen. the article i posted were for informational purposes. none of us care what your pocketbook is like. your car - do what you want. this too is coming from a V6 owner - not trying to bash - was just sharing info
Old Sep 5, 2023 | 02:00 PM
Spamfritter's Avatar
I'm not entirely sure how many things are different between the V6 and the V8 fourth generation F-bodies. The best thing you could do would be to get a running donor car and swap over everything you need, taking the time and spending the money to replace anything that is likely to fail anytime soon due to mileage, age or whatever. As far as the ECU and wiring hardness goes, I'd use a 2001 to 2002 V8 wiring harness and ECU for an LM7. Things you may have to contend with are motor mounts, front suspension springs, radiator, hoses, alternator, accessory drive, and I'm sure I've forgotten a couple of other things.
There are two sides to this coin. People telling you to sell your car and buy a different one are trying to save you some time, money and effort. The costs may or may not line up where it makes more sense to simply sell your car and buy another. If you want something like a specific color or other options then availability may simply not be there. The car being purple is pretty odd and finding an equivalent V8 car can be next to impossible. One often overlooked fact is that many of the V8 cars have lived hard lives. Unless they are relatively low mileage examples, most are ragged out and beaten pretty hard. This takes a toll in a lot of ways people don't seem to notice in the form of beat up and scratched up interior plastics, missing parts, paint damage, trashed under carriages, grenaded rear ends, and the list goes on.
A lot of the V6 cars aren't necessarily as ragged out as their V8 counterparts. Sometimes you will see absolutely gorgeous low mileage V6 cars that don't fetch a high price. Sure, its more work to swap a V8 in and there is definite cost increase that comes into play but at the age of these cars, a lot of things factor in. A lot of times you can buy a ultra-cheap V8 car that doesn't run but gives you what you need in terms of wiring harnesses, motor mount pedestals or other things. It can be potentially easier to handle as you could pay a lot less for a V6 car and build it over time versus dropping 20K+ for one of the better V8 cars.
also a good read:
While this can be true, it's not universally true. I've seen complete non-running V8 cars for pretty cheap. Some of the junk yard LSx's you can get can come with some of what you need or a lot of it for a really low price. Again, it also allows you to sometimes build something that's more unique. If I had a V6 car with perfect paint that was one of the rarer colors with a near perfect interior, I'd be looking more towards the swap versus selling my V6 car and then spending $20,000+ on an equally good example of V8 car. At one time this advice was pretty solid and nearly always true but after so many years, I think you have to take these things on a case by case basis. What does the OP have exactly? Why is he swapping it? What would he get for the V6 car versus what it would cost to do the swap, etc.?
Old Sep 5, 2023 | 02:06 PM
skl3t0r's Avatar
honestly in the here and now I'm trying to figure out whether i should dump one and a half thousand on a terminator or look for an lm7 Ecu and wiring harness at a junkyard. The swap definitely isn't cost effective, but i'm still looking to hold onto every dollar i can. I appreciate the articles, though I've read both, the reference is useful.
Old Sep 5, 2023 | 02:15 PM
skl3t0r's Avatar
That example you described about the v6 with pristine interior and perfect outer paint job- that's my car. 230k miles on it and it's beautiful. The guy who owned it before me took the time to swap trans am body panels onto it, then repainted it. So it's a v6 with a Trans Am body kit in a two-year color they made less than a thousand cars in. I want to swap it for two reasons: one, I want a faster car. With the body kit it has, it deserves a better engine. Two- 230k miles. The old 3800 is near the end of its life, and since it's my daily, it will need a new motor sometime in the next four years. So, I want to swap it, and make it a lot faster in the process. Eventually, I'm going to boost the **** out of the v8 I throw in, make it super fast. Drive my kids to school in a race car kinda thing. I've thought about getting a wrecked LS1 car, but I run the risk of something crucial being broken. It's definitely an option, though. I'll do some digging. May have to go out of state, though- The pickNpull near my house has no F-bodies at all.
Old Sep 5, 2023 | 03:12 PM
Scarebird's Avatar
I initially thought the same as the others; get a V8 car. But I cannot say that too loud as I put a 2020 crate 5.3 (Gen V) in my 71 Lemans - more room but not set up for it - at all.
So if in your shoes and planning to swap ECM's I would aim higher; think GEN IV. Better engine overall, higher power and mileage.
Though as this forum shows the Gen III's have superb support and are dirt cheap, for example: https://www.summitracing.com/parts/sum-150153
Old Sep 5, 2023 | 03:39 PM
skl3t0r's Avatar
I was thinking about throwing an lq in there, but for the time being, I want cheap power. Don't worry, though- End goal is to stuff a 502 in it and make it into a monster
Old Sep 5, 2023 | 03:58 PM
LS1 TJ's Avatar
My .02.
Do a search and find a V8 car in a salvage yard that they have pulled the engine and trans. Then strip the car of all the wiring in the engine compartment. Strip out the dash so you have the correct connections for the gauges, heater controls, steering column and other stuff. I bet they wouldn't charge much if you can do the work.
Old Sep 5, 2023 | 04:24 PM
blackbyrd's Avatar
Chassis is the same but K member has different mounting points. So you will need a v8 K memeber or an aftermarket one. Ive done the swap mine was an 01 v6 auto, now v8 manual.
I can assure you its not quite plug and play. as long as you stay within in years like swapping an 01 our to an 01 fbody v6 for v8. While its mostly stated that that 99+ engine harnesses differ from 98's and the ecms are different as well. You can make it all work, again though you arent going to unplug the harness and swap them over directly. Theres also some mechanical differences, like fuel lines, brakes, and power steering differences. suspension will also have to be addressed front springs differ slightly from v8 to v6 as well as sway bars front and rear.
When I did it I used a stand alone harness and guages and kind of ditched to stock stuff, though I dont think thats what you are going for.
I did this nearly 20 years ago now so I cant remember it all but what I found was on this site, there were several that did the same swap. So its all here just gotta search for it, you will likely see some of my posts and questions as you dig haha.
one thing I dont know is how much different the v6 systems were between the 95-97 3.8 and the 98+ 3.8? I know the electronics changed quite a bit from lt1 to ls1 so that may hurt you a bit, not sure.
Old Sep 5, 2023 | 04:49 PM
Well, the biggest issues with the V8 harnesses are that the 98 has its unique ECU that isn't compatible with the later cars. Though I've actually seen the harness repinned for the newer ECU's. The 2001 and 2002 cars don't have EGR provisions in the harness. So that's fine if you want to delete the EGR from the donor engine setup but if you don't, it's something to consider. That being said if you have an older harness like I do from 99 or 2000 you can simply ignore the connections you don't need or cut them out of the harness.
Old Sep 7, 2023 | 06:51 PM
skl3t0r's Avatar
I'm gunning for an lm7, which run from 04-10'. They should fit on holley's ls1 swap motor mounts, which I BELIEVE bolt right in to the v6 k member. I'm not sure, I need to check. Otherwise I'll have to buy one. I'm gonna keep the stock dash, and change the gauge cluster to a 1997 one, i have a guy who has a year matched brand new replacement T/A cluster. No clue how the electronics line up there. May need to just find an ls1 instead, as i don't know if an lm7 harness willcouple to the dash harness with no issues.
Old Sep 7, 2023 | 06:56 PM
skl3t0r's Avatar
Can I use an ls1 harness on a 5.3? my car's a '97, so the ecu might not be an issue. harness-wise, though, i know a terminator will go with any ls-based engine with no issues- they're just expensive. Good to know i can just chop useless connections, though.
Old Sep 7, 2023 | 07:00 PM
skl3t0r's Avatar
Just went and found a thread that said only the injector plugs are different- but I'm planning to swap the heads on the 5.3 to ls6 heads anyway. May not be an issue, depending on the year i get. We'll see.
Old Sep 7, 2023 | 07:42 PM
strutaeng's Avatar
They sell injector connectors that adapt one plug to a different type.
Or you can just solder the correct connectors on the harness.
