3800 to LS1 swap
Old Jul 26, 2004 | 08:54 AM
NFSFBody's Avatar
Default 3800 to LS1 swap
I want to install an LS1 engine and auto tranny with harness and ecu into my 1999 camaro, will everthing fit, adn connect or will i have to modify anything?
Old Jul 27, 2004 | 02:52 PM
Diablo666's Avatar
Talking
[QUOTE=NFSFBody] I want to install an LS1 engine and auto tranny with harness and ecu into my 1999 camaro, will everthing fit, adn connect or will i have to modify anything?[/QUO
I'm swaping LS6 on my 98 camaro too, so these are some of the mods you'll need to do:
V8 Engine cradle
Transmission cross member
Gas pedal and cord (on the V6 the gas pedal is electronic)
fuel tank, lines and fuel pump
if you haven't buy your LS1 and tranny yet you can get the whole pull out for about $3500 from ebay but pesonally i'm building my engine from scratch. if you have anymore questions my email is albert_boy_00@hotmail.com Good luck with your projet man!! : )
Old Jul 31, 2004 | 09:45 AM
98 Silver Bullet's Avatar
Engine
Transmission
Engine harness
K-member
radiator
PCM
You don't need a tank. Just find a sending unit/pump assembly out of a wrecked LS1. Cut an access door behind the rear seat and install it rather than dropping the tank. The LS1 fuel pressure regulator is in the tank and the V6 is on the fuel rail. You have 2 choices a 97 vette LS1 fuel rail or just cut the line just past the fuel filter, install a "T" and and back to the tank. This is how the LS1 fuel system is set up.
I'm not sure, but if you don't have V6 sport package you may have an open differential. I would replace that. It would suck having an open differential with an LS1. If you have the 2 piece driveshaft, then you don't have the sport package. You will need to get an Z28 or SS drive shaft (aluminum).
The V6 is not throttle by wire.
Old Aug 14, 2004 | 12:39 AM
1SLO6's Avatar
I beg to differ my 99 Firebird was a fly by wire. From the info I have done this is the only year with the fly by wire set up. Good Luck with the swap it is a wiring harness mess when u get under the dash.Mine was a pain!!!!!!!!!!! But as soon as your done...
