Idiot light temp switch?
Old Oct 28, 2023 | 07:13 AM
mikesimpalass's Avatar
Default Idiot light temp switch?
Hi everyone,
this winter I’ll be doing a carbed LS swap into my 67 Chevy biscayne. I would like to get the factory idiot light in the dash to work, but the factory sender won’t fit. Besides drilling and taping the water pump for the factory sender, has anyone found a good solution here?
edit:
To clarify, I’ll also be using an aftermarket temp gauge. But I would just like to get the idiot light working too
Old Oct 28, 2023 | 10:44 AM
nleming's Avatar
ICT Billet makes a sensor adapter kit I used on my last build. Figure out the thread size of your sender & check their website.
Old Oct 31, 2023 | 03:03 PM
oange ss's Avatar
Or if you know someone handy with a lathe they can rethread your factory sender for the LS1 threads
Old Nov 2, 2023 | 10:58 AM
garys 68's Avatar
There's material to drill/tap the original head location. But my 68 vette had a huge temp sender. I drilled/tapped the brass screw in drivers side block plug.
