Power door inside switches and keyless entry
Once the circuit works, refer to the keyless system's manual. Most have a bunch of ways to wire up the remote lock controls. iKey, Amazon stuff, no names etc all are different. Occasionally it matters on the lock solenoid end as a few are + or grd only, have a dedicated +/- or something along those lines. Lord help if something is mispinned or a diagram incorrect. There can possibly be alot of guess and check on this simple system
I know "refer to the manual" isn't much help, but there really isn't a way know what way to direct you without getting just as deep into the weeds with you
I finally got it figured out. I think after days of this wiring problem I just got too caught up in schematics when I should have taken a simple look at what I needed. I only needed to match and tie in the wiring from drivers door for pass door to operate correctly. All is working like it should. After thinking about it over night I came to the conclusion I was making this harder than what it needed to be. Part of this was due to wiring relays for both the inside lock and unlock switches from wiring harness and wiring in lock and unlock relays for keyless entry and the fact the generic body harness provided a lead to both doors. Don't even get me started on the overseas keyless entry for lack of instructions, but that is my fault in the end. Only one inside lock/unlock hot lead is need so as to tie both inside door switches together. In otherwords you essentally have 2 master door switches. Geez, cost me a week but hey I can get her off to upholster now. Thanks for taking your time to respond.
*BTW I blew through almost a dozen fuses getting this straightened out.
