Keeping A/C on Ls swap
Old Feb 14, 2024 | 09:52 PM
Alpha_numeric44's Avatar
Default Keeping A/C on Ls swap
I'm running an ebay standalone harness in a 94 caprice, LS Simple AC bracket and stock compressor.
I've retained the compressor wiring to thd bulkhead, but the pressure switch wiring only ran to the old PCM which was eliminated.
What do I need to do to keep my stock compressor and AC system functioning properly?
Trinary fan switch?
Stock pressure switch wired a certain way?
Old Feb 15, 2024 | 02:55 AM
pdxmotorhead's Avatar
So my jeep ls swap I've retained the Jeep AC, it had a pressure switch in the hp hard line that simply cut power to the clutch if the pressure was too low.
90's Jeeps have very basic ac , so they make a good model for DIY.... They were dealer installed on most wranglers
Cheers
