Swap cost?!?! Share your experience..
maybe i'm lucky, but i bought a wrecked tahoe for $800 that had a rebuild transmission, and so far i've kept the stuff i need (engine, trans, fuse panel, harness, computer, etc), and gotten $1100 back out of the tahoe. Seems to me that if you're patient and select a good donor, anyone can do this. A lot depends on where you live and how available donors and parts are.
the most expensive part of that swap will be, i assume, custom exhaust and custom driveshafts. kind of unavoidable. my last swap i think was 550 for the drive shaft and 350 for the custom exhaust. this one has two driveshafts so maybe a little more, or maybe not.
Swapping a stock LS1 for a 402 LS1 is not difficult, especially keeping the same trans, then you can do the rear suspension yourself later on.
Probably cheaper way, that also allows you to spread the expenses...
