4l60e not down shifting .
Old Mar 20, 2024 | 05:37 PM
aalberti's Avatar
Default 4l60e not down shifting .
I did a 07 ls swap with a 4l60e tranny has about 2000 miles on. tranny wont shift properly and doesn't down shift at all. If I test fire the 2/3 solenoid and the tcc solenoid remove the scan tool and don't shut the key off the trans will shift normally until I shut the key off for more than a couple second, the tcm resets and it is back to not shifting. Any Ideas were to look next took continuity on all the wires that run from the tcm to the transmission also pressure test was good
Old Mar 21, 2024 | 12:21 PM
mrvedit's Avatar
Moderator
This is not clear: Does the scanner show the TCM commanding shifts properly? Does it show a downshift commanded?
If yes, I will move this to the Automatic Transmission section.
