C6 ZR1 Power Steering Pump Fitting?
Old Mar 25, 2024 | 12:53 PM
TXjeepTJ's Avatar
Default C6 ZR1 Power Steering Pump Fitting?
I'm working with trying to make a power steering line w/ a 2013 ZR1 power steering pump. I figured it would be simple, but looking down into the output of the pump, there looks like a plunger that can be pushed in.
Anyone know what type of fitting this would use?
Thanks
Old Mar 26, 2024 | 08:40 AM
Pocket's Avatar
Google the ZR1 PS hose and see it's a typical saginaw fitting with a long neck. Use PN FLA-FR1634 and a high pressure AN6 hose to the gearbox. The steering box fitting can be Saginaw(most aftermarket/reman boxes) , inverted flare(factory box) or O-ring(most Ford rack conversions) depending on what you're running
Old Mar 26, 2024 | 10:27 AM
TXjeepTJ's Avatar
thanks for the reply! I have google to see what the fitting looks and found a picture that was a lot clearer. It does look like a standard fitting. I'll give that a try. Thanks!
