97 LT1 crank no start
Old Mar 27, 2024 | 09:11 PM
951LT1's Avatar
Default 97 LT1 crank no start
Porsche 944T LT1 swap.
Have FP prime, rail press, ICM connector tests all good 1-4 acv pin c cranking 12v a & d b grd good, coil test 12v, Opti harness connector 12v 5v 5v grd. Grounds clean&tight
Old Mar 28, 2024 | 07:04 AM
33willys's Avatar
Back to basics. Are the injectors firing? Test with a noid light. Do you have spark? Test with a timing light.
Old Mar 29, 2024 | 12:41 PM
951LT1's Avatar
No spark. Replaced coil and ICM last night no change. Have Inj pulse, fuel press., correct voltages to all harness connectors.
