Getting OBD to work
Old Apr 7, 2024 | 05:41 PM
Andrew Kirk's Avatar
Default Getting OBD to work
I'm doing a LS1 swap with a 0411 PCM. I connected the ground pins, 12V constant, and serial data pins to the PCM to power it up and flash a tune with HPTuners. I'm getting a "Detect Protocol Failed" in the VCM Editor when connected to a MPVI3.
Does the hptuners software need all sensors to be connected for it to read the PCM? I'm confident the wiring correct since it's pretty straightforward. I submitted a support ticket but figured I'd try here too
Old Apr 8, 2024 | 08:25 AM
bobcratch's Avatar
no. but you do need ignition to be hot, pin 19 on the blue connector
