Turbo drag and drive engine prep
Old Apr 12, 2024 | 09:48 AM
cadivette's Avatar
Default Turbo drag and drive engine prep
It's been a few years since I've worked on anything of my own for a fun project. So here's ti the start of one I'm excited about.Turbo LS for a future drag and drive car!!
Old Apr 12, 2024 | 01:13 PM
Full Power's Avatar
What ya building ?
Old Apr 17, 2024 | 05:38 PM
LSswap's Avatar
I'm assuming you're going to a electric water pump to cool the car down between drag runs. I used to have an electric water pump, but that was for a dedicated, trailered drag car.
I also have a turbo drive and drag car. It has a conventional water pump. I run the temps at 180 at the track and 195 for cruising. The car has a 160 thermostat and can adjust the engine temperature with the radiator fan which is PWM controlled with a closed loop to the engine temperature. Takes only a few minutes to cool the car down to 180 in the staging lanes with the engine running.
Old May 6, 2024 | 11:08 AM
cadivette's Avatar
Originally Posted by Full Power
What ya building ?
02 Blazer
Here's the start of the build series
Old May 6, 2024 | 11:12 AM
cadivette's Avatar
Yes a Davies Craig pump. . My biggest reason was room. I had an LS2 vette pump on the car when it was NA and had very little room for Dan's, car ran hotter than I liked. I upgraded the fans to a Derale set up so room it a premium now.
I follow Kevin at KSR and he runs a similar set up on their drag and drive car that is way faster than ill probably be.
