Ls swap c10 help!!!!!
Old May 25, 2024 | 05:25 PM
1981c10ls's Avatar
Default Ls swap c10 help!!!!!
Looking for help on my c10. Since this post u did replace the crank sensor with no change. Think I may be onto something…. When I installed terminator x and used wizard I had setup map as internal 1 bar(hose running from intake to pcm) and put left stock map in intake unplugged to block the hole, now I have back from tuner and noticed it’s plugged in. So I unplug it. Truck dies… hmmm wasn’t dependent on that before.. so I try to reset in handheld back to internal and it will not overwrite. Suggestions appreciated
Old May 28, 2024 | 08:53 PM
the_merv's Avatar
Veteran: Air Force
The Computer needs that MAP to run, why the tuner plugged it in and it ran before you unplugged it and reset thinking you knew better than the tuner.
Plug the Sensor back in and stop trying to overwrite ****.
