need help!!
Old Jun 5, 2024 | 06:38 PM
grey_bird95's Avatar
Default need help!!
okay so I have a 95 trans am t-56 car. I have recently done ls swap on it. been having non stop issues with car wanting to rev up to 3k on start ups, yes ive traced down vaccum leaks and throttle body iac tps temp sensor you name it ive done it. anyways long story short, im buying a 99 engine harness from a friend, my question is just using the engine harness am I going to have to change the whole bcm and dash harness as well from the 99?
please help thank you all!
Old Jun 6, 2024 | 08:38 PM
the_merv's Avatar
If you have it running now why are you changing the wiring? Sounds like the tune is off.
I wrote the book on making a LS wiring harness that's a direct swap into the LT Fbody. I've done many of every year, it works.
https://ls1tech.com/forums/conversio...o-lt1-car.html
