153T flywheel and starter
Old Jun 22, 2024 | 11:30 AM
scatillac's Avatar
Unhappy 153T flywheel and starter
For those of us who are "bellhousing impaired" , from what I can gather, McLeod has/can make a 153T flywheel for Gen3/4 that will accept a 10 1/2" clutch but that is just part of the issue.
In sourcing a starter, I've had no luck.
Has anyone out there done this?
A larger bellhousing would solve the problem, but create a lot of firewall problems and I'd rather not cut up the car.
Old Jun 22, 2024 | 12:21 PM
Pocket's Avatar
You can try contacting these guys if they'll sell just the starter
https://www.marks4wd.com/mfk1947.html
Tilton makes a nose for their starter body that positions it for 153tooth
https://www.sriperformance.com/Tilto...s-54-40012-Sta
Bit of advice, if it's just the floor clearance, then cut the floor. Sheetmetal is much easier to work around than a custom starter. If the starter was an easy solution, then you'd see vanilla LT1 style T56's used in LS swaps
