Rough Idle/Lean AFR
Old Jul 29, 2024 | 03:26 PM
904Jamo's Avatar
Question Rough Idle/Lean AFR
1994 K1500 with a 5.3 swap. Recently started having some AFR/misfire issues. Went through the spark plugs, coil packs, checked for exhaust/vacuum leaks. At a loss here, any insight or ideas of whats going on would be appreciated. At idle not in gear, it idles high/rough. When shifted into gear the truck bogs down sometimes shutting off and then jumps back to normal idle. When driving around, anytime 30% or more throttle is applied AFR shoots up to around 25-30. Video is attached for reference. Thank you.
Old Jul 30, 2024 | 05:02 PM
the_merv's Avatar
Veteran: Air Force
Have you checked the Fuel Pressure at the Rails?
Old Jul 31, 2024 | 12:27 PM
904Jamo's Avatar
yes I have, they’re reading fine
Old Jul 31, 2024 | 01:03 PM
Kawboom's Avatar
I've had a similar issue with a carbureted engine, and I think it's misfire. The O2 sensor reads unburnt air, not fuel or lack of fuel. I would set the Terminator X to open loop at idle, not use the O2 sensor, and you can tune it like a carb where you find the settings where you get maximum vacuum at your desired idle RPM.
Old Jul 31, 2024 | 05:45 PM
the_merv's Avatar
Veteran: Air Force
Yea, what is "fine"?
