1971 Ford LTD
As soon as it was home, it seems like my motivation hit like a ton of bricks. As I was looking over the car I noticed the solid engine mounts, and after some half behind measuring and some just stupid luck, my mockup block fit with the use of OBS chevy ls swap brackets and some spacers to take up the rest of the mismatched mount width. These cars had front sump oil pans originally and I knew i wanted to shove the engine as far down and back as physically possible. Seeing the original HVAC box was damaged and fixed in the past, I decided to just start sawing till I liked what I saw.
After a bunch of time and dust, I decided it was just best to remove it completely and push the engine back. I wanted to keep stock style AC, but it will now get a vintage ac style kit.
Last night I threw in my 4.Great to finalize mount placement, set myself up to build a transmission mount, and prep myself for the BFH message this trans tunnel is about to receive.
I will try to keep this updated, and also do my best to take pictures to share. I always forget the before shots. Ha
They only made that body style for 2 years so to me that makes them even better...
(I have a 1971 Ford Custom 500 ex Minnesota highway patrol car with the factory 429 Cobra jet in it.)
I cannot wait to see how this turns out!!
I also took the firewall to pound town but may need to pull the engine I prematurely installed to get a better hit on edge of the firewall and the tunnel.
Not much progress, but like they say, it's like eating an elephant, you take one bite at a time.
Next I installed my radiator and fan from the last project, into the stock location. Plenty of room for activities for future plans. Luckily when I ordered an parts, I ordered extra fitting and hose, and those came in clutch when I had to make new ones that would reach.
As I said before I was on the hunt for a set of long tubes because I'm not quite sure if I'm going to go turbo AGAIN or maybe use my LSA blower set up. Well after spending a good amount of time looking at pictures, I bit the bullet grabbed a set of C10 swap headers to try. Low and behold, the fit AMAZING. May end up keeping them for round two.
Im trying not to take forever and lose interest, so I decided to rebuild the Holley black pump and regulator that were already on the car, add a China dual plane, OLD MSD 6010 controller and a Holley 600 cfm carb. Exhaust is straight tubing to some cheapo mufflers. Got a great deal on a Gbody driveshaft, but i need a slightly longer yoke. Next plan is a better shaft, but that's future Me's problem also, I realized I put the muffler on upside down. HA
I keep forgetting to document stuff until its already finished, but ill keep trying, and ill keep updating.
