Ls swap gen 4 ecu issues
Old Aug 20, 2024 | 11:16 AM
Harzy7's Avatar
Default Ls swap gen 4 ecu issues
I am ls swapping my genesis coupe and I used a 2011 express van 2500 with the 4.8. Ecu and engine with a standalone harness, I have everything wired and when cranking I get no spark signal and no injector pulse, I can see rpm on hp tuners while cranking, I have replaced the crank sensor already and no change, I disabled vats as well, I'm very lost as to why I don't have any spark, this is a steel block gen 4 58x with vvti however I'm not running the vvt setup just unhooked so should be default to center, if anyone has any recommendations please let me know thank you!
