Obd2 port data wire question
Old Aug 31, 2024 | 06:24 PM
chrisv45's Avatar
Default Obd2 port data wire question
So currently I'm working on a 97 Chevy obs with an lq9 swapped. Data wire is there but for some reason I get no continuity between the obd2 port and pin 59(purple wire) which is odd because it is the same color wire. Would I be able to run a wire from the pcm to the obd2 port or is there anything else connected to that wire that would prevent anything else from working? This is the last thing and I don't want to fry anything and hopefully not take anything else apart to do this. Everything else works, ground, 12v ect on the obd2 port and pcm but am getting a fail to communicate message on my scanner. Any help would be appreciated.
Old Aug 31, 2024 | 09:27 PM
ls1nova71's Avatar
On a swap that wire usually doesn't go to anything else, so you should be able to run a new wire if you think it's broken somewhere.
Old Sep 1, 2024 | 07:44 PM
chrisv45's Avatar
right on thanks
