Cam for 6.0
Old Oct 15, 2024 | 03:50 PM
Leonard&Lola's Avatar
Default Cam for 6.0
I have a 6.0 DOD engine that I am changing over to NON DOD and am looking for suggestions on the largest cam swap I can do without having to do any machining on the heads/block etc. I would like to keep the stock pistons as well. This is going in a 40 Ford truck street rod, and I don't need tons of horsepower, but want something that sounds nasty. Any recommendations would be appreciated.
I have looked at the Chopacabra from Texas Speed, is there anything else in a kit out there that is bigger/better and sounds nasty without getting a custom grind?
Thanks in advance.
Old Oct 15, 2024 | 03:57 PM
Look at the Lil Chopper cams at Cam Motion if you're strictly going for sound.
Kind of a poser move, but you do you....
Old Oct 15, 2024 | 04:07 PM
Project GatTagO's Avatar
Thanks in advance.
I tune a lot of engines with the Chppacabra and Truck Norris cams. Both have good manners and have a nice chop. I would not hesitate recommending either one. From a tuning perspective, they behave almost identically.
Andrew
Old Oct 15, 2024 | 04:12 PM
68Formula's Avatar
Summit Racing™ Big Nasty 5/4 Race Cams
Summit's Big Nasty 5/4 race cams are made in the USA and that should tell you something right there. You want overlap and chop? You've come to the right place. They have the overlap of big race cams YET work with a stock converter and flat top pistons! They makes so much torque, gears are no longer required - but 4.11's are always the fastest. Headers and free flowing exhaust recommended but Zoomies really let folks know you're not playin' around. If you can tune for one of our Stage four race cams, you've got the right stuff to tune these. Gas Mileage not included.
Notes:
Stock pushrods ok. No Flycutting required. Zoomies Highly recommended. Stock converter ok but 5000 stall and 4.11's always better. SUM-174002 LS6 valve spring required. Gas mileage not included. Tuning required.
https://www.summitracing.com/parts/s...GBJZGgcW1KLK94
Old Oct 16, 2024 | 08:39 AM
Summitracing's Avatar
LS1Tech Sponsor
Hey @Leonard&Lola,
We agree with @68Formula and want to share some additional details to help you choose the SUM-8733R1 "Big Nasty" 5/4 Race Cam! The specs are impressive: .550/.550 lift, 218/230 duration, 105+3 LSA, with 14° of overlap.
Check out these videos for some inspiration:
  1. First Start Video: This clip from slammin86 features an '87 Chevy R10 with a 6.0L engine running the Big Nasty cam. It's the first start on an old tune, idling around 750 RPM. If you're looking for that aggressive chop, this cam delivers!
  2. Tuned Idle: The same setup after some tuning shows how much smoother the idle can be with a bit of work.
  3. Dyno Test: Richard Holdener ran a dyno test comparing the SUM-8733R1 to our Pro LS Stage 4 SUM-8711R1 in an L33 5.3L with Trickflow heads ported by BTR. While both cams share 14° of overlap, their specs are quite different. After installing the Big Nasty cam, peak numbers came in at 459 hp at 6,500 RPM and 438.8 lb.-ft. of torque at 4,800 RPM. Interestingly, while peak horsepower was lower with the Big Nasty (488.5 to 459 hp), peak torque increased (438.8 vs 432.5 lb.-ft.). The biggest gains were seen below 3,000 RPM, where the Big Nasty delivered an additional 50 lb.-ft. of torque! The comparison starts at 11:50.
We think this cam will not only give you the performance you're after but also the sound that turns heads at car shows. Everyone will be asking about that chop, and you can proudly tell them it's running an LS with the "Big Nasty" from Summit Racing
Let us know if you have any more questions!
__________________
800-230-3030
www.SummitRacing.com
Old Oct 16, 2024 | 02:20 PM
Thanks so much for the links, so I can hear what this cam sounds like. This is what I am looking for! Do you sell a kit like BTR does with the correct push rods, lifters, springs, etc that are all matched for this cam swap?
Old Oct 17, 2024 | 11:45 AM
LS1Tech Sponsor
@Leonard&Lola,
That sounds great! We sent you a private message about a kit we could put together for this.
__________________
800-230-3030
