67 Cadillac Deville
Old Oct 20, 2024 | 11:38 AM
Dorseyboy30$!'s Avatar
Default 67 Cadillac Deville
I have a client that’s had a 67 deville some else did the ls swap on it he called talk about his reverse like and signal not working my ? Is do he have to be standalone harness or can his stock cluster be hooked up to work with his ls 5.3 swap
Old Oct 23, 2024 | 07:16 AM
clay68c10's Avatar
The reverse light switch is on the column so it shouldn't have anything to do with the swap. On those cars the switch has a vacuum portion to disengage the park brake. They are not easy to source.
The temp gauge will need to have a 67 compatible sensor added to the engine. The speedometer will need a mechanical input. Either from a modified tailshaft housing or one of the drive boxes.
