Eps steering
Old Nov 23, 2024 | 07:51 PM
Pyobluebonus's Avatar
Default Eps steering
I'm installing eps from a 2015 -2019 kia soul. The 2 10ga. Wires are 12volt + an - which terminal energizes the ecm module I can not find a diagram that shows the terminal. Thank you in advance
Old Nov 23, 2024 | 08:29 PM
Double post.
Go to the lower right of either post, hit Edit, and go from there to delete either one
Old Nov 24, 2024 | 05:53 PM
ls1nova71's Avatar
Neither of those two wires go to the ECM. Looks like there is an 8 pin connector on the MDPS unit that has 2 CAN wires that go to the ECM. Good luck getting that to work with a GM computer. Probably best to not try and hook that part up and let it go into default mode.
