LS7 cam sensor/o2/lean issues
Old Jan 4, 2025 | 02:46 AM
garte5's Avatar
Default LS7 cam sensor/o2/lean issues
so i inhereted a 4th gen camaro with an ls7 swap. engine runs fine until it warms up, at which point it starts surging. has engine codes so i ran an obdII scan on it, and is throwing codes for "camshaft position sensor circuit a bank 1", "o2 sensor bank 1 high voltage", and "bank 2 too lean". the car is running on a modified ls1 ecu. the car was driven fine a year ago, had a starter issue so it sat until now. was wondering if this could be faulty ecu or if it could be a wiring harness issue. i just find it odd that all of these seemingly unrealated codes would just appear after having sat for a while and done a starter.
