Power steering pumps and reducers
What's the best spot to purchase a power steering reducer? I have an 05 CTSV powertrain in a 91 240sx hatch and the pump sends 1500-1700psi where my rack wants 1100-1200psi. (similar to f-body numbers I believe)
The fear is blown rack seals and bad road feedback. Pump whines a bit under normal use. similar to when you're at full extension or when PS fluid is low.
Are guys running just a reducer? or a reducer and undersized pulley at the PS pump? I've been searching, and it seems like there is a divide. Some say its not an issue, some say they dont know why they keep blowing seals, others say reducer, and others swear by reducer and undersized pulley on every swap they do.
Any info to help would be awesome.
-Adam
I don't know what specific PS pump you have, but many have springs or shims which can be changed to regulated pressure. They are located under the high pressure fitting.
