L33 build
Old Mar 29, 2025 | 10:24 PM
Ikemcmike's Avatar
Default L33 build
Picked up an l33 the other day, it came with a set of 706 heads. With the flat top pistons, small cc combustion chamber on the 706s, and the truck Norris cam I was hoping to slap in it I’m a bit worried about valve clearance. Also planning supporting bolt ons. Seeking advice, is this a terrible setup? What would you do considering a limited budget? Anybody running this setup? What power might it make? Lmk!
Old Mar 30, 2025 | 03:09 AM
Not_usually_UK's Avatar
Check out Richard Holdener as he tests a 5.3 fairly standard setup with the Truck Norris & other cams that will help show your likely improvements (
Clearance won't be an issue, but you need to budget for a set of springs, unless you use the NSR version.(https://www.summitracing.com/parts/btc-s0393)
Old Mar 30, 2025 | 08:19 AM
Ikemcmike's Avatar
Thanks man! I wasn’t aware of the nsr cam! I’ll probably still do springs and lifters though, just for peace of mind.
Old Mar 31, 2025 | 01:44 PM
ryeguy2006a's Avatar
I'm running the LS6 Power Max Plus cam from Scoggin Dickey in my LC9 and it runs great. It's a 220/222 with .570" max lift made for LS3 springs.
https://sdparts.com/i-24138755-sdpc-...hoC4nMQAvD_BwE
Old Mar 31, 2025 | 02:07 PM
gnx7's Avatar
Those heads (mildly ported and performance valve job), as much compression as you can run for the fuel in your area (alum block/heads LS supports 11:1 easy on 91 and around 12:1 on 93), headers, LS6 intake manifold (great bang for the buck or Trailblazer if it fits), healthy cam should make very close to 380-400rwhp depending on transmission.
What vehicle is it going into and intended use? In something light that would be a very fun combo.
Old Apr 2, 2025 | 11:13 AM
Ikemcmike's Avatar
it’s going in my 05 rcsb so I’m thinking tbss will happen, it’s going in front of my old 4l60, whenever that gets slushed I’m probably gonna try to go with a t56 or tr6060 if budget allows. Also have 93! 300 wheel was my initial goal, anything beyond that is bonus points.
