How to control 2022+ 10L80 with Electronic Shifter?
I have a 6.2L L87 engine and 10L80 trans drop out from a 2023 Sierra truck. The 22.5+ trucks switch to the console shifter that is electronic with no physical shifter cable.
Is there any easy way to control these transmissions for shifting from park, drive, reverse etc for a swap application?
Speartech sells a 10L80 floor shifter with Tap Shift but it still uses a cable for the actual shifter.
Yea I talked to spear tech this morning and they don't have any plans on making a solution for this. I've talked to a couple other swap harness makers that said people are working on it but none of them have details on who/what/when so I have my doubts about that.
There has been talk of a 10L90 controller solution for about a year now. As far as I can tell, it is vaporware at this point.
The ZF8HP is a better transmission and is supported by many companies.
Andrew
