LS1 swap O2 sensor malfunction
Old May 13, 2025 | 09:12 AM
edmcdow's Avatar
Default LS1 swap O2 sensor malfunction
I have an LS1 swapped 240z with reprogrammed ECM and stand alone wiring harness. Finally got things running a few weeks ago. It seems to be running smooth at idle but it was extremely rough off idle. Monitoring with HP tuners I noticed the short term fuel trim on both banks would creap down to -12 to -14. I figured my O2 sensors weren't working properly so I swapped them with new AC delco and I now have a constant 450 reading on both bank 1 and 2 O2 sensors. I double checked the wiring on the O2 sensors and they look correct. I measured the purple and tan wires coming from the PCM and they both read 4.5vdc to ground??? Is this normal? It all appeared to work OK prior to swapping O2 sensors I was just trying to correct the fuel trims.
