Gauges cluster not working after swap
I have 96 Camaro , I swapped engine to L77 engine I took that engine from 2011 caprice SS.
my issue the gauges not working properly. RPM , Speedo, oil pressure. Should I replace aftermarket gauges ( Dakota or NVU ) or can I keep the original gauges ?
Lol okay. What else was swapped over?? ECU? Your gauges probably aren't compatible with the newer sensors from that engine. You'll need either get sensors on the engine that will work with your gauges or just go aftermarket.
