L84 Swap - No Fire
Old Jul 6, 2025 | 10:05 PM
Chasechad22's Avatar
Default L84 Swap - No Fire
2020 L84/8L90. Return line fuel pump. 80psi at regulator and 2100 at FR. Reading 150ish cranking RPMs and 12V while cranking. I have power/reference at coils and cam/crank sensors. Pedal and MAF installed. I am not seeing spark when I pull a plug. I’ve check every connector and ground. VATS disabled. Desperate for help. Thoughts? Thanks in advance
Old Jul 7, 2025 | 05:53 PM
ls1nova71's Avatar
There's a couple of VATs that need to be disabled, are you sure they all are? Also you need to disable the starter diagnostic.
Old Jul 7, 2025 | 11:37 PM
Thanks Ls1nova71, I had Texas wiring specialists flash the ecm for me and they claim they did. I am about to invest in HP tuners so I can get a better look into this thing. I’m just completely lost as I’ve tested everything I can think of.
