C6Z Ls7 to Ls3 swap questions??
Im sure some of you will think this is treason 😆 but I picked up an 06 Z06 with no motor. I want to swap an Ls3 into it. I've done quite a bit of research on this but was looking for some input from those who have actually done this swap. Everything looks like a pretty straight forward swap. I'll be going wet sump, and I've read that I'll need roughly a .400 spacer to bolt up the t56 to the ls3 because the ls7 snout in longer. Can anyone confirm this and recommend vendors who sell what I need?
Did the terminology change on Engine parts in the last week or so? I missed it.
LS7 has a longer Crank Snout because of the Dual Oil Pump for the Dry Sump. Has absolutely nothing to do with a Crank Spacer that goes on the BACK of the Engine.
I'm stating that off of what is said above until I'm shown otherwise.
A GrandSport C6 is a c6z with an LS3. Both are drysump cars. If I were you ls1 charged, I’d find a drysump pan and simply drysump the LS3. I realize the dry sump oil pump is hard to find, but they are out there. I’ve got one on the shelf. I see LOTS of Oem drysump oil pans in the classifieds, on here AND on Corvette Forum. A wetsump C6Z will be worth Pennie’s on the dollar for resale. Do it right. You won’t regret it.
