Electrical help please
My question is can I use my pink ignition hot wire and parallel it with another wire fed off a relay triggered by solenoid cranking wire so I get +12 in both key positions? Is there an easier way?
Rick
To make a LS swap the run the best it needs super good grounds and clean 12 volt positive connections. No old nasty hacked up old wiring.
