LS1 or LT1 into 87 firebird
Old Aug 2, 2004 | 10:40 PM
87_formula's Avatar
Default LT1 parts swap into 87 formula....need help
i have an 87 formula with the 350 TPI and the engine recently seized up and ive been lookin to replace that engine with an LT1. i have found a 95 firebird and i want to purchase it as a parts car for my beloved 87 but i wasnt sure if some of the parts were compatible. i was just wonderin if any of you knew if the 95 rear end, seats, and tires and stuff would fit on my 87. please reply if u know anything
Old Aug 2, 2004 | 11:01 PM
Kevin Hall's Avatar
The rear end is wider to allow to larger wheel offset. If you're planning to use the wheels and tires, this is good. HOwever, the fronts will need a 2" spacer. The seats are a direct replacement.
Old Aug 3, 2004 | 10:54 PM
87_formula's Avatar
Default LS1 into 87 firebird
will an LS1 swap right into an 87 formula or will other things need to be changed along with the engine?
Old Aug 3, 2004 | 11:54 PM
Vendetta's Avatar
You'll have to change quite a bit. I believe the front suspension will have to be modified. This post would do better in the hybrid section than the LT1 section...
Old Aug 4, 2004 | 02:16 AM
transamshh's Avatar
Checkout these website's, between the two of them you will find everything you need to make a LS1 swap into a third-gen.
www.hawksthirdgenparts.com
www.thirdgenresource.com
Old Aug 4, 2004 | 09:03 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Here's a better play by play install into our 91 Z28.
http://www.speartech.com/coproj-1991ls1.html
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Aug 4, 2004 | 02:25 PM
crainholio's Avatar
Also lots of good data at the top of the Engine Swap forum on www.thirdgen.org/techbb2 on this.
Old Aug 11, 2004 | 06:16 PM
thebeast_93LT1's Avatar
sorry, i don't mean to hijack your thread but... any links on fitting an ls1 into a 93' z-28? thanks. ttt for ya'!
-Daniel
