Heater hose connections
Old Aug 4, 2004 | 06:38 PM
Uk Robert's Avatar
Default Heater hose connections
Almost finished ls1 install into Ford(mercury)Capri but i`m stuck with the heater hose connections. The outlets come off the water pump/thermostat housing. Can i connect them both up to each pipe in the heater or are they in fact routed differently............like via the bottom radiator hose outlet? In my Chevy LS1 install guide they list the bottom hose as connecting to the heater outlet off the thermostat housing. Is that correct?
Old Aug 4, 2004 | 07:17 PM
crainholio's Avatar
Mine are routed as you describe, and that's the net routing of the native 4th gen F-body platform. Coolant just loops thru the heater core and back to the water pump.
