PNP sensor?
Old Aug 31, 2004 | 01:17 PM
whitesmokels1's Avatar
Default PNP sensor?
when i got my ls1/4l60e tranny, it didn't have the park neutral position switch on the side. Do i really need this for the car to drive. I have a painless harness with the PNP connectors.
Old Aug 31, 2004 | 08:37 PM
Lostpatrolman's Avatar
Im not positive, but i think that without it the car wont start.
Old Sep 1, 2004 | 10:55 AM
CamaroCain's Avatar
With the painless harness it should be fine without it. The reason it did not come with it is because f-bodys have it attached to the shifter not to the transmission, so you couldnt really hook it up unless you had the f-body shifter assembly any way. The 2 things the pnp does is connect to the starter relay to only allow the vehicle to start in Park or Neutral, which is a good feature, as well as work the reverse lamps.
