Starter wire
Old Sep 3, 2004 | 09:33 AM
Budman78's Avatar
Launchin It!
Default Starter wire
Why do I have a wire marked starter ignition? Does it need to be hooked up to the start to start the motor. My vette harness already has a wire to signal the starter and it currently turns the motor over.
Old Sep 4, 2004 | 12:57 PM
Scooter70's Avatar
Are you sure that it's not just the wire that's supposed to be connected to a +12V ignition switched source? Is it coming from the new fuse panel to a fuse? If that's it, it just tells the PCM when the key is turned to ON. I connected that directly to the original fuse panel to the spade labeled IGN.
-Matt
Old Sep 6, 2004 | 09:00 AM
Budman78's Avatar
Launchin It!
No, I've got that one connected to the ignition wire that is original to the car. I think it is pink.
Old Sep 6, 2004 | 02:37 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
If it's the big purple wire, I label it as "Starter, If Needed". If you already have your own vehicles starter wires hooked up, you can just cut off the big purple that is part of the factory harness.
If you're talking about some other wire, I don't know. I was thinking I did your harness, but maybe not.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Sep 6, 2004 | 06:38 PM
Budman78's Avatar
Launchin It!
You did and it the purple one. I will just kill it. Thanks. John and Matt
