would my alt fit?
As I am always wondering about my project, as I am now.
Since I would like to swap a LS1 in my car, I sold my old 350 chevy engine, but not the almost new 160 amp alternator form mr. alternator.
Would there be any way to adapt this alt to an LS1 on the same spot the alt normally is on the Camaro LS1 setup?
If it fits, how will it be in size comparred to the stock LS1 alt, mounting and clearance wise...?
It has a normal v-groove pully for now and normal mounting places for a old 350. It has a 4 wire connector, the big power post and a internal regulator. Would it hook upto the computer and wiring harness?
I would realy like to use this alt again an dsave some money, instead of buying another high output alt for the LS1.
this is a shot of the alt on my old engine:http://www.xs4all.nl/~pjtimmer/4_res..._placed001.jpg
I hope you can help me out,
thanks
Peter
If you use some type of custom adapter or bracket, your alternator could work with a 6 rib pulley and the correct electrical connector on the back.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
As I look at it, I could be possible, I will keep the alternator for now and see if I can adapt it later on or sell it anyway.
Thanks
Peter
