HELP! installing f-body master in 55 chevy
Old Sep 5, 2004 | 02:14 PM
55LS1's Avatar
Default HELP! installing f-body master in 55 chevy
I need some guidance, I am at the point where I need to install the master cylinder and pushrod in my 55 chevy. Has anyone done this before? I have heard you can use the original hole for the mecahnical linkage, but I'm not sure which way to go. Thanks for the help.
Old Sep 7, 2004 | 07:35 PM
John B's Avatar
Moderator
All you really need to do is make sure your angle is correct and you have full travel.
Old Sep 8, 2004 | 12:42 AM
55LS1's Avatar
does the rod need to be straight so when the pedal is pushed, it will go straight in and out? or is it at a slight angle? My firewall is completely flat, so if it has to be at an angle, I am guessing I will have to mount it in a lower position. Thanks for any help!!!
Old Sep 8, 2004 | 01:28 PM
John B's Avatar
Moderator
You just need to make sure that wherever the attach point to your pedal is, that the rod is kept perpendicular (at a 90 degree angle) to the clutch master cylinder.
