ls1 in 68 firebird problem
Old Sep 19, 2004 | 08:57 AM
68birdls1's Avatar
Default ls1 in 68 firebird problem
i am trin to put my 99 ls1 in my 68 firebird with the s&p adapter plates and stock motor mounts but the thing just wont go in the way it is supposed to! i cant even get one whole lined up. i had a set of solid mounts on there and i could atleast get one of the wholes to line up but i am absolutely stumped! any advice on what i should do? thanks in advance
daniel
Old Sep 19, 2004 | 09:13 AM
NOSjohn's Avatar
Restricted User
1 person doing a motor swap can get frustrating. I would suggest getting 1 hole lined up with motor mount to frame mount and put a bolt through it, then try to finess the other side to line up as well. It may take a pry bar, if you're doing it yourself, or give a call to a friend to help manuever the motor.
Old Sep 19, 2004 | 09:17 AM
68birdls1's Avatar
thats the thing, i have people helpin me, its just that i think i might have the wrong mounts but i dont know!
http://yearone.com/serverfiles/fbshopmain2.asp?cat=8
is the link to what the motor mounts i have look like. they are the ones at the bottom, i didnt buy them from year one, but that is what they look like! which on that page do you think i should get?!? thanks
daniel
Old Sep 19, 2004 | 09:20 AM
Budman78's Avatar
Launchin It!
I had to have a friend stand on the driver side to get it to go down. It's definely a two man job.
How far off is it? 1/8", 1/4" ?
Old Sep 19, 2004 | 09:57 AM
68birdls1's Avatar
on the solid mounts that i have, i could get one whole to line up, and the other one was all the way on the frame mount, but was no where near the whole. it would of had to go down and to the left! i dont know what could be wrong with it other than i dont have the right mounts on there!?!
daniel
Old Sep 19, 2004 | 10:20 AM
NOSjohn's Avatar
Restricted User
On the old 'birds, didn't they have multiple holes in the frame rails? Are you sure you have the frame mounts in the same spot/holes?
Old Sep 19, 2004 | 10:39 AM
68birdls1's Avatar
there is only one way to put the frame mount on though! there is an extra whole but it gets covered up by the mount!
Old Sep 20, 2004 | 06:08 AM
Hersker Hans's Avatar
Try to post some pictures. Might be easier to see the problem.
