Starter wiring question
Old Sep 21, 2004 | 10:54 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Starter wiring question
I have a Painless wiring harness and there are two red wires (zip-tied together) that are supposed to go to the "big" terminal on the starter. The "big" one I assume is the positive power terminal, which also connects directly to the battery.
What are those two wires for? Is this how the PCM is getting its power?
Do I just use the original 69 ignition wire to fire up the solenoid input terminal?
Just want to make sure before trying to start the engine for the first time.
Old Sep 22, 2004 | 11:40 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I think I may have answered my own question. I put those two wires onto the battery terminal and turned the ignition to "on" and the SES light now comes on like it should. All I need to do now is route the ignition/starter wire to the solenoid signal terminal and it should fire up.
after I install the fuel system of course
