Automatice transmissions codes
Old Sep 27, 2004 | 09:10 AM
boner58's Avatar
Question Automatice transmissions codes
I ahve finally got my truck to run a 1994 4x4 fullsize chevy with a 5.3 lt out of an 03 tahoe and an automatic transmissions I used the factory harness from the motor and my question is I am getting a lot of codes from my transmission and I was wondering if I didint have power to something? and if anybody could help me out Thank you Daniel
Old Sep 27, 2004 | 12:37 PM
patriot68's Avatar
what codes???
check the E(pink) wire at the trans. it should always have 12 volts with the key on..it shouldnt drop below 9.5 volts during start up...
Old Sep 27, 2004 | 05:28 PM
boner58's Avatar
Originally Posted by patriot68
what codes???
the codes are
p0740
p0753
p0758
p01860
Old Sep 27, 2004 | 07:48 PM
patriot68's Avatar
all these codes at once ar mostly caused by an electrical problem..check the the outside and the internal trans harness for exposed broken wires...
if both look good get a wiring diagram for the trans and check the crimp at circuit 1020...bad crimp on at this circuit is very common
could be caused by a bad ecm as well...
Old Sep 28, 2004 | 08:31 AM
boner58's Avatar
I actually do not have an ecm all I have is a pcm but I will check the wiring this weekend thank you for the help
