Ram Jet 350 or Ls-1
Old Oct 11, 2004 | 10:36 PM
Cozmo's Avatar
Question Ram Jet 350 or Ls-1
I am looking in to swap either a Ram Jet 350 or Ls-1 into 1st gen. camaro with a 6 speed manual. I think that the Ram jet is easier but it will be a daily driver and want to know how it is on gas compared to the ls-1? If anyone has any idea it would help.
Old Oct 12, 2004 | 11:01 AM
Project GatTagO's Avatar
I wouls think that a stock LS1 with a 6speed will get better gas mileage then a Ram Jet.
Andrew
Old Oct 12, 2004 | 05:40 PM
Keith's Avatar
As far as I know. The ramjet runs in open loop, without an oxygen sensor, possibly using more gasoline.
Modern technology is your friend, Use the LS1.
Old Oct 12, 2004 | 09:37 PM
Cozmo's Avatar
I figured the ls-1 would get better gas milage but does anyone have a ram jet in anything and have the mpg?
Old Oct 13, 2004 | 12:15 AM
boondiggys's Avatar
exactly the ram jet is still 2nd generation all iron ls1 all aluminum and is the way to go
Old Oct 13, 2004 | 07:42 AM
crainholio's Avatar
While the LS1 probably does get better cruising mileage, I have difficulty staying off the loud pedal...the thing's just too much fun.
The engine I replaced was fairly similar to a Ram Jet. GM L98 rebuild, 10.7:1 compression, AFR 190 heads, GM HOT cam, and TPIS Mini-Ram intake. It was a blast to drive, but the LS1 really gave the car a new personality on the road course.
Old Oct 15, 2004 | 05:28 PM
Oscar Will's Avatar
I have a freind with a Ramjet in a '50 Chevy Sedan Delivery and it really hauls but even with the 4L60 and 3.42 gears it only gets 14-15 mpg. An LS-1 in the same vehicle I'd bet would do better than 20mpg..........and be alot more drivable and "cruizin" friendly.
