99 corvette filter
daniel
daniel
If I had it to do over again, I'd take the rail off and weld a fitting onto it. (When I take the engine out to powdercoat the frame, I probably will) There is a guy here in town who does custom brake lines, power steering lines and for about $20 he'll weld a male AN -6 to your rail. Perhaps there is somebody where you live who will do a similar service.
If you can weld or braze yourself, you can buy a -6 37deg flare JIC fitting at any hydraulic supply store and drill the center to slip over the fuel rail and weld/braze it.
