Oil Pan
Old Oct 22, 2004 | 09:04 PM
svt's Avatar
svt
Default Oil Pan
Got my oil pan back from the welder. Came out pretty good. I would highly reccommend him if you are in norca and are going to do your own. The place is in Mountain View, CA called Advanced Welding, the guys is into hot rods and old motorcycles, he also does motorcycle welding. Real nice guy too.
Now I can keep the factory bracing on the pickup tube and windage tray which also functions as a brace. And for less then half the cost of buying one online, but I did cut the pan myself and welded the pickup tube myself as well.
One question, the bottom of the pan says alignment is critical, but I don't see any locating pins, what do they mean by this?
Thanks,
Marc
Ls1/T56 -> 69 Camaro
Attached Thumbnails Oil Pan-dsc02631a.jpg   Oil Pan-dsc02648a.jpg   Oil Pan-dsc02661a.jpg
Old Oct 23, 2004 | 01:31 AM
6_7_camaro's Avatar
Nice Welds - Looks like you took off just enough for clearance
What did he charge?
Old Oct 24, 2004 | 06:30 PM
John B's Avatar
Moderator
Flushness with the back of the block when installing the pan to the block.
Old Oct 25, 2004 | 12:12 PM
svt's Avatar
svt
Thanks! I was hoping it was something that simple.
I actually cut too much out, I think I could have gotten away with about 30% less front to back, then I could have used the stock pickup tube without any modification, shoot I wouldn't have even had to remove it. Like they say, hindsight is 20-20.
Old Nov 1, 2004 | 06:27 PM
Oscar Will's Avatar
Actually that oil pan to bellhousing spec is almost nothing, the factory book calls for 002", they just don't want unnecessary stress on the pan or the bellhousing. Very nice job!!
